Results 1 to 2 of 2
Thread: Fuel pump relay
    Nov 2002
    Jersey
    38
    Exclamation Fuel pump relay
    The fuel pump on my car continues to activate after my car is turned off, i have been told it is my fuel pump relay, by any chance would anyone be able to tell me where it would be located?
    Aug 2002
    Butler, PA
    659
    Re: Fuel pump relay
    Pull away the carpet in the trunk on the left side. Then pull out the 2 push pins and take the black plastic cover off. You should see a little green box with a few wires coming out of it. That is your relay. Hope this helps.
