Results 1 to 2 of 2
Thread: 93 Supercoupe ShortBlock Rebuild Questions
    Hey guys, I have a nitrous'd 97 3.8 Mustang and am building a new motor for it.
    I will be using a 93 supercoupe shortblock w/ Ross Forged Pistons, 93-95 SC Rods. Here are my questions.
    1. What size main bearings, rod bearings, and cam bearings do i need? Any brand recommendations? What place sells them cheapest?
    2. What rod bolts should I use for the 93-95 rods?
    3. Any recommendations for main studs?
    4. I need to use a 93 balancer and crank pulley. Do they make UD crank pulley's for SC's?
    5. Do I need rod bushings for the 93-95 rods?
    That is all I can think of for now. Any links or part #'s to the parts mentioned above would be greatly appreciated.
    Thanks,
    Zach
    1,599
    Re: 93 Supercoupe ShortBlock Rebuild Questions
    Thanks,
    Zach
    1.any 89-95 bearings will work
    2. ARP rod bolts (they are similar to 2.3L bolts I believe), or ask ARP who carries the V6 packaged rods(ARP doesnt sell them direct for the SC)
    3.ARP
    4.yes, but its setup for the SC accessories(ASP makes it)
    5. 89-93 rods are the same as the regular 3.8 rods I believe, 94/95 are free floating and weigh slightly more(stronger), you need the small end rod bushings if they are worn out
    6. try SCCOA "Links" for links
