Results 1 to 5 of 5
Thread: Head Gasket Failure - Where did your gasket Leak?
    JT Guest
    I just took off my heads and found the gasket failed on the Passenger side between the rear cylinder and the water jacket at the rear of the block. Where did yours fail?
    GEORGE ONEILL Guest
    Re: Head Gasket Failure - Where did your gasket Leak?
    Mine leaked at 4 & 5 on drivers side wich you failed to have in you poll
    Charles Markman Guest
    How about all? I had failure in four of the six fire rings.
    Charles
    Louchios Guest
    Mine was between the rear and middle drivers side. Damn near cracked the head. It also looked like the rear pass side was getting ready to go.
    Canada
    160
    Mine didn't blow, but the fire ring looked like it was being sucked into the bore at the rear water jacket on the passenger side. I couldn' get an answer to my question,so i've told my story here
