Results 1 to 2 of 2
Thread: Fuel Pressure Regulator
    What is the difference in fuel pressures between a '90 w/30# injectors and 94/95 w/36# injectors? Is it necessary to change the fpr when upgrading injectors? How much "range" (in pressure) is available if you go to an adjustable fpr? The car will have a 255 lph pump.
    Thanks,
    Mike
    20,939
    Mike,
    Both are set at 39-40 psi. It isn't necessary to change fuel pressure settings especially if you have a tuner or re-burnable chip. Back when I had 38# injectors without a tuner, it required increasing the fuel pressure to around 43-44 psi to prevent bogging at launch.
    If your just switching to 36# injectors, I don't think you need to do anything else except recalibrate the MAF.
