Results 1 to 5 of 5
Thread: rear brake question
    Nov 2002
    53
    rear brake question
    Was in lookin at my brakes and on the left rear the outside pad was worn rite out and the inside pad was in perfect shape, would this be a cause by a bad caliper?
    Thanks for any help
    Joe
    Aug 2002
    Down by the river.
    311
    bad rotor is more likely
    Nov 2002
    53
    rear brakes
    I replaced the rotor and pads tonite drove home and the left rear brake was HOT. So i am guessing the caliper is hanging up?
    Dallas, TX
    5,755
    You're guessing correctly. Pull it, clean the slider pins, regrease them, and try it out.
    Jan 2003
    22
    An excessivly worn outside pad is caused by the slides hanging up. An excessively worn inside pad is caused by a caliper piston sticking/brake hose gone bad. Use synthetic grease and dont over grease the slides. I use Silglyde at the shop i work at and it does an excellent job.
