See if this helps. Note, on the SC, those 2 outlet tubes at the top of the WP aren't there. There is just one tube. And, on the bottom left side, there is a tube which is not in the picture.
10 is a stud as shown, but a very long one (please no jokes yall) 12 is a stud that the top HB cover attaches to.
Every thing else is correct. One other note.. the torqe specs say 20 lbs.. DON"T DO IT! Thats wayyy too much for all that soft metal. 10-12 lbs MAX! Thats more that screwdriver tight, but less than wrench tight. IT will be more than sufficient. You also don't need 1 tube of permatex. A thin layer on both sides of the new gasket is sufficient. Its about a teaspoon total.
