Hi
I have vibration problem with rear wheels.
Some time ago the bushings for rear, upper control armer (inner side, around inner control arm-to-sub-frame bolt) were changed by the Ford service. Are these inner side bushings non-symmetric (=left side different from right side bushings) or is it installation that they must be installed differently on left and right side? Now these bushings are installed non-symmetric: right side is installed differently than the right side which means that right side is installed more forward than left side. Ford service says that this is OK and correct. Could this kind of installation of upper control arm bushings cause vibrations of rear end of the car?
Best regards
Kai Hamalainen
kai.hamalainen@ailocom.com
Best regards
Kai Hamalainen
