can anyone help with this code?
ssgohan796
hey hows it goin? i have a 90 sc and my check engine light comes on parieoticly and my cars idle like crap and almost stalls i ran my car on a code scanner and im getting the code of 66 which is MAF CKT (circuit) below minimum voltage and im also getting the code 98 which is hard fault is present if you can help me out a little bit it will be greatly appreciated
thx,
steve
Sounds like...
I would start by checking the wiring harness near the MAF sensor. Maybe try to clean the sensor with a type of cleaner designed for that purpose.
If the code still shows (probably will), replace the MAF sensor itself, one of the filament wires in the sensor may be actually broken.
Do you use a K&N air filter? Check for oil build up on the sensor filaments as well.
Phil
maf
i have tryed exchanging the maf from my other sc and it didnt do anything and i have a stock air box on right now. i will try cleaning it out and see what happens
