Results 1 to 6 of 6
Thread: Aluminum driveshaft out of Mark VIII?Need help
    uniqueredsc Guest
    Will a 93LSC driveshaft bolt on right to a 1990SC?Is there any modification to do regarding on this swap?Need help on this one fellow SC'ers.The Mark VIII driveshaft is wayyyyyyyyyyy lighter than the SC one.Anybody?H E L P...........
    Bill A McNeil Guest
    Re: Aluminum driveshaft out of Mark VIII?Need help
    I'd like some info on this as well. I think it would go nicely with a McLeod flywheel eventually.
    Hope somebody nows.
    Peterdroy66 Guest
    Aluminum MkVIII shaft
    I looked into this last year, and it is not a direct bolt in. I have a 90 SC with AOD. I think the Mk shaft is shorter than our stock shaft, But I honestly don't remember the details at this point.
    anybody with a 4.6L would likely be able to swap this in easily, and you can get them used for $100 if you are lucky.
    If you find out anything different, let me know.
    Thanks
    fast Ed N Guest
    Guys, the Ford parts catalogue does not give any dimensions on the shafts, but it does break down the slip yoke, u-joint, and axle flange numbers. The only SC cars that have the same front slip yoke as the Mk 8 are the 94-95 AODE cars. Looks like all 93-98 Mark 8 use the same shaft. So there could be a length issue, and a yoke compatibility issue. I think this is something you would have to eyeball with the two driveshafts side by side.
    cheers
    Ed N.
    johnny o Guest
    I'm pretty sure guys where modding the Crown Vic Police Interceptor shafts for use with their SC's. I don't have any details other then I remember it's too long and needs to be shortened.
    gaspeddle Guest
    I can't offer any advice, but the next time I get under mine I'll measure the length.... I know some years were 2 piece and others 1 piece.
    Jim Prince
