Results 1 to 2 of 2
Thread: Where is the fuel pump relay on my 89 SC?
    Aug 2002
    Rock Hill, SC
    I am going to be changing out my early model gas tank today to a 92-up style, problem is I have about 5-7 gallons of gas in the tank. I want to locate the fuel pump relay and jump it out so I can pump all the fuel out to a couple 5 gallon containers so getting the old tank out won't be so much of a paint in the A$$.
    Which wires should I jump to do this?
    Lakeville, MN
    You can run the pump with the self test connector for the engine.
    Below is a picture used for checking fuel pressure to run the pump. Same will apply for what you're trying to do.
