Results 1 to 5 of 5
Thread: help!!! I need a vacuum diagram for an 89!!
    Apr 2003
    orlando fl
    658
    please if anyone has one email me a link or something?! please throw me a freaking bone here.
    Nov 2002
    Syracuse, NY
    504
    what exactly do you need to know?
    joe
    Apr 2003
    orlando fl
    658
    egr?
    Im almost done on my engine install, i need to know where the map sensor hooks into, and where does the egr transducer hose hook up? The labels got greasy and wore off I feel like a dumb ***.
    1,599
    its a BAP, doesnt hook to vacuum. The EGR hose goes from the fitting on the lower portion of the EGR pipe to the transducer bolted beside it(fitting underneath). The EGR vacuum line has a 90 degree bend(the one that actually plugs into the top of it), and the other side goes to the solenoid beside the relays just beside the A/C accumulator, the other side of the solenoid goes to the vacuum tree under the cowl area I believe. If someone has a Chilton manual it also has emission diagrams in there
    Nov 2002
    Syracuse, NY
    504
    assclown is correct there is no vacuum line that goes to the b-map. it's not the same sensor that is on the n/a v6.
    joe
