Thread: Spark Plug help needed.
    Bill A McNeil Guest
    Hey boyz,
    I will have to make up my mind on a decent set of plugs, preferably one step colder than the stock Motorcraft plugs from what I see most are using with great success.
    I forget the final outcome of the SCCOA post that lasted almost a month regarding this back around Christmas time, anybody remember? I'm guessing there was no final verdict, but maybe some key favourites.
    Anyway, the Denso part # is IT20, but I don't know what the stock replacement number would be from them? I may give these a go considering they have been used by some and have been featured in Musangs and FF used on a Lightning to pick up like 30hp. I think it was the Denso if I remember correctly. They are an Iridium spark plug.
    Any input would be helpful.
    Thanks,
    Les Borda Guest
    Re: Spark Plug help needed.
    Check with Dave Dalke(XR7 Dave) I think he uses those fancy pants plugs. Otherwise try the Ford AWSF32PP's and gap them between 45-50 rather than the recommmended 54. Even on the stock plugs a tighter gap then 54 seems to work better.(I remember that long drawn out plug conversation, or a good part of it anyway).
    sabbySC Guest
    32PP's or get the Denso's Dave is running but rememger your not at the point where you need them yet. NGK makes a decent iridium plug as well.
    For the money I say go with 32pp's once you've got everything running right and tuned properly than you can switch to something more exotic if you feel its needed.
