Results 1 to 6 of 6
Thread: Help me decipher Codes for my sc :O)
    NYC
    17,431
    Ok finally my car (94 sc automatic)did the christmass tree thing again and I hooked up the good ol trusty MATCO scanner,,Here's what I got.
    Stored codes were 176 I believe bank 1 lean
    and 543 Secondary fuel pump circuit
    Now I believe 176 refers to a bad o2 possably but what about 543?...help?
    Also when doing the engine run test when it asks to blip throttle and al that crap I got a 136 which was lean bank 2
    and a 225 which I think was knock sensor..Which is brand new however in this heat and humidity with my boost I'd assume it would go off..
    So basically change O2's and????....Any idea guys
    Thanks ..Damon
    NYC
    17,431
    ANYONE????
    Forked River, NJ
    2,092
    543 is "Fuel Pump (FP) circuit open connection - Electronic Control Assembly (ECA) to battery".
    Maybe you're getting lean codes because the fuel pump isn't getting enough juice.
    I'd check all the fuel pump wiring if it were me.
    NYC
    17,431
    I could also be running lean because I have stock injectors and 21 psi...Anyopne else have any ideas before I go ripping through it?
    Sep 2003
    Oklahoma
    132
    Fuel Pressure
    Key on - 35-45
    @ Idle 30-45 Vacuum Hose attached to reg.
    @ Idle 40-50 Vacuum Hose detached to reg.
    Hold pressure after 5 min. 30-40
    max pressure 65
    ck. voltage @ fuel pump relay to pump location #4 pink/ black wire
    Sep 2003
    Oklahoma
    132
    code 176 / 543
    Let me know what you find. We are trying to trace down wiring problems on a friend of mines '92 sc. code 176 / 212/ 542
