Results 1 to 4 of 4
Thread: Supercharger Oil
    Jun 2003
    Oviedo, Fl.
    760
    Supercharger Oil
    OK .... I'm sure this question has been asked before, but I'm some what new here so I'm gonna ask again.
    Is there a compatible oil available other than the EXPENSIVE stuff Ford sells ? Is it cheaper and would it be in a larger container ? I want to change out the oil in my SC but don't want to be ripped off by having to go to the dealer to obtain it . My 93 SC has 183,000 miles and up to this point I just keep the level where it belongs.
    Jun 2003
    Arizona
    173
    Talking Supercharger oil
    Yeah, go to your local Pontiac dealer and ask for Grand Prix supercharger fluid. The part number on the 4-ounce bottle I have says 1 #12345982.
    I've been told it's the same or better than the motorcrap stuff and it is only $7.36 compared to around $18. What the hell is Ford thinking anyways.
    Hope this helped.
    Illinois
    1,744
    Months back, I paid 25 dollars for 4 ozs!
    There is a jet engine lubricant available that can be a direct replacement for the SC fluid. Fully synthetic and its actually rated to withstand extremes better. A search will reveal some of the brands its sold under & the part number, but it is available from small airports & marine type stores.
    As an alternative, you can use 0w-30 or 5w-30 synthetic motor oil. This is directly from the owners manual included with your Supercoupe. I don't know if it has the same protection properties as the normal oil, but it obviously is acceptable. Just remember that if your snout seal is leaking & slinging fluid, it might make things dirty underhood.
    Jun 2003
    Oviedo, Fl.
    760
    Yea, It leaks a little but nothing to be to concerned with. Needs about an ounce every 30-40k miles. I just would like to change out as much oil as I can suck out with a baster or somethig simular.
