Thread: Lentech vs Transgo
    Mt. Pleasant, North Carolina
    26
    Lentech vs Transgo
    I am in the process of trying to figure out which way to go. There seems to be a post on the subject but seem most are talking about an AOD trans. I have a 94 with the 4R70W (AODE), does anyone have a Lentech valve body in a AODE or the Transgo kit? I sure could use some real world help with this one, por's and con's.
    Thanks
    JimmyB
    94 SC
    211,000 mile and still going....
    Lakewood, CA
    1,122
    I don't think you need Lentech with an AODE. It will lock out OD on its own and doesn't it have 1-2-D as a shift pattern, with an OD delete? Either way I would just go with a strong build up and a transgo kit to make it right.
    Va Beach,Va
    1,042
    look into the "Jerry Mod",you can reprogram your valve body for stronger/tighter shifts.....check the TCCOA Tech Articles,it's an option to consider.
    z
