Results 1 to 5 of 5
Thread: fuel tank swap ?
    Aug 2002
    TX
    262
    fuel tank swap ?
    I'll be swaping the tank in my '90 for a later year model in few weeks.
    Will the sending unit and pump assy from the later model work with my car without mods.
    I do plan on a 190 pump but it would be nice if I can install it on the later unit. That way I can do it at my convenience before dropping my current tank.
    Will the sending unit power my gauge properly?
    Jan 2003
    Great Lakes region
    1,009
    When I put a '94 tank in my '89 all I did was put a new pump into the '94 tank, then bolt it into the '89, everything plugged right in and worked.
    Aug 2002
    TX
    262
    Thank you. That's the info I needed.
    Lakeville, MN
    13,517
    Check out the MN12peformance website. Rich recently posted a how to on swapping the fuel pump out with one of the kits that he sells there. It has pictures and descriptions on removal of the tank that could be very helpful for you.
    Aug 2002
    TX
    262
    thanks for the info, I'll be there in a minute to print out his instructions for the pump swap.
