Results 1 to 5 of 5
Thread: Question about lifters
    One of my lifters is bad and I need a new one. Is there any way to buy just one? Also, are SC lifters the same as the NA 3.8 lifters?? TIA
    1,599
    yes, all 5.0 lifters are the same also. Ford or any parts store should have some, about 10-15$
    Feb 2003
    Phildelphia, PA 19030
    2,181
    Talking ROCKERS
    ARE ALL 3/8 ROCKERS ..1.73 RATIO................AND CAN YOU USE THE 1.73 ON 3/8 N/A??????????????????? FAST FREDDIE
    Los Angeles
    210
    What are symptoms are having in regards to your bad lifters? Just curious. Thanks
    It was knocking really bad, sounded like a bearing had gone out, but it was very high in the engine. I took the drivers side valve cover off and the rocker arm was loose because the spring in the lifter had collapsed, not letting the pushrod hold the rocker arm up.
