Results 1 to 2 of 2
Thread: Will this Work
    Jan 2003
    38
    Exclamation Will this Work
    I am looking to build my own exhaust and i have been reading some of the threads but i am hoping one of the more experienced members will read this and ok it. I Have a Completely stock 94 auto SC and i am getting ready to change the exhaust. I wanna put some header and down tubes then run 2.5 duals all the way back all i want is a resonator. Is this posible without the cats or will my car run really weird. Also about how much power increase will i obtain with this exhaust and a 10% overdrive pulley.
    21,151
    Assuming the resonator will have dual inlets and dual outlets, yes you can do it and the car should run fine. However without mufflers it may sound louder/worse than you think. Unless your planning on a big cam and ported heads with oversized valves, porting the stock manifolds will provide plenty of flow. I wouldn't expect more than a 10 or 15 HP increase from the exhaust, even with the headers.
    On a stock SC the 10% would be stronger on the bottom end but may consume more power than it makes on the top end. The pulley should add around 20 but putting a 10% pulley on a 94/95 blower is like a 13% on an early model SC. I would suggest a 5% instead, which is like 8% on an early model.
