Maintenance Schedule?
Flip
Just got our first SC about three weeks ago, in great shape. Is there a general maintenance schedule somewhere for an SC? Intercooler clean, etc… guidelines?:D
SERVICE INTERVALS -- PERFORM AT THE DISTANCES OR MONTHS SHOWN, WHICHEVER OCCURS FIRST.
NOTE:
Items for Emission Control Service are shown in this type and style.
FOR ITEMS MARKED WITH A NUMBER IN PARENTHESES SUCH AS (1), SEE FOOTNOTE AT THE END OF THIS SECTION.
NOTE:
Schedule A provides maintenance intervals for replacing your air cleaner filter if you drive in severe dust conditions. However, the conditions you drive in may require even more frequent air cleaner replacement intervals than those shown. Check with your Dealer.
ONCE A YEAR
l Check engine coolant protection, hoses and clamps.
EVERY 36 MONTHS
l Replace engine coolant.
EVERY 60,000 MILES
Supercharged Engines--
l Replace spark plugs (platinum).
Regular Maintenance Intervals
3,000 MILES (4 800 Kilometers)
l Change engine oil and oil filter every 3,000 miles or 3 months.
6,000 MILES (9 600 Kilometers)
l Rotate tires.
9,000 MILES (14 400 Kilometers)
12,000 MILES (19 200 Kilometers)
15,000 MILES (24 000 Kilometers)
l Replace PCV valve--3.8L engine. (4)
l Replace PCV valve and crankcase ventilation filter--5.0L engine. (1) (4)
18,000 MILES (28 800 Kilometers)
21,000 MILES (33 600 Kilometers)
l Rotate tires.
24,000 MILES (38 4000 Kilometers)
27,000 MILES (43 200 Kilometers)
30,000 MILES (48 000 Kilometers)
l Replace engine coolant every 30,000 miles or 36 months.
l Replace spark plugs--except turbocharged engines.
l Inspect accessory drive belt.
l Replace air cleaner filter. (1)
l Inspect exhaust heat shields.
l Change automatic transmission fluid. (2)
l Inspect disc brake pads and rotors (front), all 4 supercoupe. (3)
l Inspect brake linings and drums (rear). (3)
33,000 MILES (52 800 Kilometers)
36,000 MILES (57 600 Kilometers)
l Rotate tires.
39,000 MILES (62 400 Kilometers)
42,000 MILES (67 200 Kilometers)
45,000 MILES (72 000 Kilometers)
48,000 MILES (76 800 Kilometers)
51,000 MILES (81 600 Kilometers)
l Rotate tires.
54,000 MILES (86 400 Kilometers)
57,000 MILES (91 200 Kilometers)
60,000 MILES (96 000 Kilometers)
l Supercharged engines--replace spark plugs (platinum).
l Check supercharger fluid level.
l Replace spark plugs.
NOTE:
Rear axle lube quantities must be replaced every 100,000 miles (160,000 km) or if the axle has been submerged in water. Otherwise, the lube should not be checked or changed unless a leak is suspected or repair required.
(1) If operating in severe dust, more frequent intervals may be required. Consult your dealer.
(2) Change automatic transmission fluid if your driving habits frequently include one or more of the following conditions:
-- Operation during hot weather (above 90°F, 32°C), carrying heavy loads and in hilly terrain.
-- Towing a trailer or using a car-top carrier.
-- Police, taxi or door-to-door delivery service.
(3) If your driving includes continuous stop-and-go driving or driving in mountainous areas, more frequent intervals may be required.
(4) This item not required to be performed, However, Ford recommends that you also perform maintenance on items designated by a (4) in order to achieve the best vehicle operation. Failure to perform this recommended maintenance will not invalidate the vehicle emissions warranty or manufacturer recall liability.
