Results 1 to 4 of 4
Thread: probably a common question...my cooling fan quit?
    Apr 2003
    Sherwood Park Alberta Canada
    50
    It could be my fault as I took it off along with the radiator a week ago....but either way it dosent work.....Is there a relay switch or fuse that could be to blame?....did i screw up the computer?....or do they just quit?
    Thankyou for any help
    Keith
    Canton (Atlanta area) GA
    1,089
    Are you sure it stopped working? A quick way to be sure is to cut on the A/C and check to see if the fan kicks on. If it does, you should be OK (unless the IRCM isn't getting signal from the temp sensor, or the IRCM is shot). If the fan doesn't kick on, cut the A/C off or you may overheat the condensor.
    If your fan motor connector is anything like mine, you may have a bad connection. Replacing the old plug connectors may solve the problem...
    Apr 2003
    50
    yep
    it dosent work at all.....it wasnt running at all last evening and it wasnt working this morning when I went for a spin....I looked at the fuse boxes and didnt find anything, I will look at the connector and fan itself when i get home.
    What is the ICRM?...control module for the fan?....maybe a sensor quit?
    Thanks
    Keith
    H-Town Tejas
    2,891
    Do a search for cooling fan, this question comes up all the time.
    Jeff
