BlownMerc
Well I just now pulled off the L/F actuator cover to discover that this lovely $120 FoMoCo Part is not workinng properly. Anyway my question is:
When I apply pressure with a pair of small pliers to the small "rod" which turns the valve inside the shock, clear fluid comes out. It looks strikingly like SHOCK FLUID. So dose this indicate a bad shock or is this normal on our car's setup.
If its bad I'll install the Illumina II's inplace of the Ford OEM's.
Thanks for any help,
Brad Mason
Brad Mason
