Page 1 of 11 12345 ... LastLast
Results 1 to 15 of 152
Thread: Wierd Problem- Experts help
    Nov 2002
    NJ
    1,024
    Ok heres what happened, I'm driving down a highway, doing like 80mph and I slow down at the light, start moving again, gun it in first gear, get to like 35mph, then this car goes in front of me, and i shift into second gear and give it gas- but nothing it felt like I was in fourth gear ( No i wasnt lol )..and then a check engine light comes on. It felt like it was on 3 cylinders, the exhaust sounded wierd and the idle was half of what it should be so it would make sense that it was only running 3 cylinders.
    So I get home, go inside, pop the hood... and I was like let me drive it again, so my bro and me go around the block, its acting the same then all of a sudden the check engine light comes off and booooooom its back to its normal self...? So what could it be?
    Also one more thing, my boost gauges stop reading after 5psi, it doesnt feel slower, it feels exactly the same, the vac/pressure reading is 20psi(or whatever the rating is ) so I know I dont have a vac leak... I have an aftermarket one also, so I dont think its the factory guage...
    Please help me figure this out...
    Ed
    - Also no upshift arrow when starting the car.
    South Florida
    471
    I had this similar problem. Cylinders 1 and 5 went out, then came back to life on it's own - this was a recurring problem. The car idled at 500RPM - the motor shook side-to-side like a pendulm. It had less power than a Geo Metro. Getting the car to highways speeds was a big challenge.
    I dismounted the DIS module, sanded down the bottom of the DIS, and the ground bracket it lays on. Spread some fresh dielectric grease underneath the module, and remounted it - haven't had a problem with it since. Runs like new, again.
    Dielectric grease - $2.99
    Ford Ignition Module bolt remover - $4.99
    An SC engine running back to normal - priceless...
    For everything else, there's Mastercard.
    Nov 2002
    NJ
    1,024
    I was thinking about doing that, the DIS felt very hot..
    but anyway lol, is the DIS bolt remover a special thing? since I'm not going outside to check, I figure i'll make sure lol... where can I get some of this Dielectric grease?
    Thanks for the reply.
    South Florida
    471
    You can get the 'Ford Ignition Module Bolt Remover' any local auto parts store, that carries minor specialty parts. If they ask you the size of the bolt, tell them it's 5.5mm or it's converted SAE size, which is 7/26" I think - it says it on the packing slip of the part.
    As for the dielectric grease, you can get that at any auto parts, or hardware store.
    Allentown, PA
    733
    Ford had a technical bulletin on the, 'Ford Ignition Module Bolt Remover', tool..
    The Ford technicians were having trouble trying to figure out how to use it.
    They are instructed to take an 8 hour course to refresh their skills, and remind them, "righty tighty.. lefty loosey".
    Toronto, Ontario
    172
    Don't use dielectric grease!!
    You should be using "Heat sink compound" on the DIS, not dielectric grease.
    You can buy it at Radio Shack.
    Nov 2002
    NJ
    1,024
    my shop manual says...
    DIS Ignition Module
    Removal
    1. Disconnect negative battery cable.
    2. Disconnect both electrical connectors at the DIS ignition module assembly by pressing down on the locking tabs where it is stamped PUSH and remove the connector.
    3. Remove module retaining bolts and remove module.
    Installation
    1. Apply an even coat of approximately 0.80mm (1/32 inch), Silicone Dielectric Compound WA-IO, D7AZ-19A331-A (ESE-M1C171-A) or equivalent to the mounting surface of the DIS module. Install module and retaining bolts. Tighten bolts to 2.5-3.5 N-m (22-30 lb-in).
    2. Connect both electrical connectors to module.
    3. Connect negative battery cable.
    Lakeville, MN
    13,517
    Note that in that text they give a very specific part number. There are any number of Dielectric silicone greases out there with various additives to give various performance characteristics.
    In the case of the DIS, the characteristic that you want is to transfer heat into the bracket the DIS is bolted to, turning it into a big heat sink. For this to work you need to make sure your Dielectric grease has thermally conductive metal oxide powders mixed in it. The easiest way to do that is to purchase Heat Sink compound, which is basically Dielectric Grease with metal powder to transfer heat.
    The key with the DIS is make sure the bolt that grounds the unit (lower right) has a clean connection. And that the unit is kept relatively cool.
    Oct 2002
    Lincoln, NE
    2,062
    Mike8675309,
    Could you post a pic (from above) with an arrow in an effort to dummy proof which bolt provides the ground. I've been having a slight studdering problem and believe it to be a ground...I just want to make sure that I have good contacts there for the ground. Thanks.
    Jun 2003
    Vancouver, Washington USA
    1,740
    I have a : 'Ford Ignition Module Bolt Remover' for sale at only $5 and I pay shipping!
    I agree, use HEAT SINK compound. Radio Shack or any computer store sells this stuff. They use it to mount the processor to the motherboard. It shouldn't cost more than $3.
    Nov 2002
    NJ
    1,024
    umm well it was doing the same thing when I woke up this morning, so that tells me that its not from the heat although I just put new heatsink lubricant on it, sanded the surfaces... no changes... so what do I look for now?
    PLEEEEEEEEASE HELP :-D
    20,948
    Mine did the same thing several years ago. At first it was just once every few days, before a couple weeks passed I could barely drive it to the dealer.
    It needed a new DIS module..I suspect you do too.
    Nov 2002
    NJ
    1,024
    I know two cylinders arent firing, its the two toward the windshield washer resevior,
    like this...
    X X O
    X X O
    --------------> driver side
    The two circles represent the ones not firing... so anyway where can I get a new DIS? is it going to be a ~~~~ like everything else I need for this car..?
    South Florida
    471
    like this...
    X X O
    X X O
    Those two cylinders are on the same ignition circuit, so it definitely a DIS issue.
    Surprisingly, DIS modules aren't hard to find, you just might need to special order one - worst case scenario. If you plan on keeping your car for a long time, get a brand new one. If you want a used one, you can search the classifieds. You can't get just any DIS module - there are two different kinds of waferboard DIS ('89-90 and '91-'93). Make sure you get the right one.
    You can get a new Motorcraft DIS at the (St-)dealership for about $340 in change, Autozone has a generic OEM version of the DIS for $99, NAPA sells their generic OEM version for around $160, partsofamerica.com sells their's generic OEM version for about $130. All of these places have a Limited Liftime Warranty, except for NAPA (only 1 year).
    If you have the money, get the Motorcraft. If you get it anywhere else, be sure to save your receipt - you might need it. I only say this, because Genuine Motorcraft parts tend to be more reliable, than generic.
    Nov 2002
    NJ
    1,024
    are the other ones crappy or something? I mean the $99 sounds good to me lol.
    I went to the autozone.com website and they have one listed for $99 but they call it the Control Module.. is that what I want?
    thanks.
