BlckOnBlckBrd
Ok here's the deal, I turned a corner today, lose power, check engine light comes on, and tach drops about 300 RPM. I drive about a half a block trying to figure out whats going on and it just all of a sudden runs like normal again (Does this off and on thing for a little while). I get it home and run the codes on it. I get a code 124 (TPS voltage higher than expected) and a 217 (Ignition system problem Coil #3 primary circuit failure).
The 124 I don't think is the problem and was just stored in the memory, but I think the coil is the problem. I think it is, I just wanted to verify from the experts if thats what you think it is too before I spend $80 on a new coil pack tomorrow.
Also, could anyone tell me what codes 32, 36, and 76 on the ABS system mean?
TIA
TIA
