P
p0werg0d
Guest
new member- big trans problem!!
i have a 90 sc with the dreaded aod. i just got it cheap. the car only has 77000 on it. i realize now why it was so cheap. after 3 days of normal driving the car feels "hung up" in second gear. if i put it in D it will hold in second until max rpm. at part throttle around 45-55 mph it will start to slip until i press full throttle and it will accelerate normal until max rpm. if i put it in OD it will act the same but after45-55 mph the rpms will fall to 1700. any higher speeds and the motor will free rev unless wide open throttled. then it will downshift to second. im assuming i got burned and this aod is trash. but if anyone has any experience here with quick fix it would save me around 1200 bucks.. i have tried moving the tv cable setting with no avail. it just modifies the point at which it will shift from 1st to second. and just for good measure- I STILL WHACKED A SATURN WITH NITROUS BETWEEN REDLIGHTS. other than this problem the car is pristine and i only paid 2500 for it. so its not a massive tradgedy yet. thanks guys!!!! john
