Results 1 to 15 of 30
Thread: Cobra Rear Axles ?
    Bristol, CT, USA
    1,121
    Cobra Rear Axles ?
    Can we use Mustang Cobra Rear Axles ?
    is it the same length as ours ?
    i know we can use there rear diff and and hubs..
    just not sure about length, anyone ever look into this ?
    would it be an upgrade for ours ?
    Just something i was thinking of because i remember someone saying about the for CV joints are discontinued...
    Alex LaChance
    My Dyno Run
    Pics + Video
    220 RWHP (So Far)
    325 RWT (So Far)
    http://www.bristoldyno.com
    My Mods + Future Mods
    http://www.tccoa.com/rides/lacale.shtml
    My Website With Pics + Others
    http://community.webshots.com/user/supercoupe
    Oct 2002
    Lincoln, NE
    2,062
    If I'm not mistaken, the cobra (I'm thinking '03) has a 31 spline axle where we have a 29. I think before '03 though everything should be the same, but I don't know for sure. I'm just going off memory here.
    Jan 2003
    Columbia, SC
    3,468
    No...the only transferable parts from a 99 Cobra rear IRS are the hubs (if you are going to change to the 4.5" bolt pattern) The rotors (if you are going to change to the mustang rear brakes and you need to fab. a bracket for the calipers as well for that) and the center pumpkin or differential which is a direct bolt in and has a housing made from AL). The later model Cobras went to a 31 spline setup so in that case nothing is directly teransferable.
    Forked River, NJ
    2,092
    99 Cobras use a 28 spline diff.
    All later Cobras use a 31 spline diff.
    All IRS Cobras use 28 spline hubs.
    The Cobra half-shafts are about 1.3" too short to use on the MN-12.
    Sep 2002
    Effingham.IL
    5,011
    With the shorter stang shafts being 1.3.I wonder if it would be worth making
    shorter top and lower arms to narrow the rear end for,so wider wheels could
    be ran on the rear of a SC.
    I haven't looked just a thought.I have been thinking of making some lighter
    and stronger arms for my rear end when I get to that part of the SC.I wanted
    to put some machVIII arms on the rear but have not found any to use.So I have
    been kicking around fabing some out of some 4130 I have.Anyone think the rear
    could be narrowed the 1.3 inch.each side with the stang shafts, aluminum center section,
    stang hubs.You know just swap in the hole stang rear end,with new arms.
    Any one got a idea of how big a can of worms this swap would be,for a narrowed rear.
    Thanks Randy
    Thats an interesting idea! Especialy for guy's wanting that Pro Street look or guy's runing drag cars. A shorter axle would have less twist also.
    Forked River, NJ
    2,092
    It's an interesting thought, but I wonder if the wheel wells wouldn't then be the limiting factor.
    It'd probably be much easier to just transplant the entire Cobra subframe somehow, then to start fabbing shorter arms, and dealing with attendant geometry issues.
    Somewhere out there
    3,477
    Question Hmmmmm.......
    I have looked all over for a '99 Cobra differential. I have also looked for a lincoln mark VIII differential. I have had no luck on the internet. Maybe i'm looking in the wrong places. Any ideas?
    dirtybird91
    Sep 2002
    Effingham.IL
    5,011
    DFL , I would think the wheel wells would be easy to deal with if that wide
    of a tire would be used to set inward that far.Or wheel off set.
    If the stang subframe could be used,or be moded to be used.Do you think
    just the stang lower and uper arms could be used?
    It would be nice to get some 315+ series tires on the back.And have all the tire inside
    the fender.
    I had talked with DOUG FRANKLIN about making up a upper and lower a-arms
    for the SC.He & I wanted the single upper bolt mounted arm to be replace, with a a-arm.
    Making the rearend of the SC have a upper & lower a-arms.We thought this would help stabilize
    the rear end for his roadracing and my drag/roadracing.And help reduce some of the wheel hop.
    If the IRS stang shafts are 1.3 shorter.This would give the SC a 3.1inch narrower rearend.
    That would seam to be about right for some descent size rubber under the back of a SC.
    With the proper wheel offset.
    I beleive Keny Brown has made a SC sub-frame,and now makes a sub-frame for the stangs
    so maybe he would know if the swap is possible.As far as swapping the sub-frames from a
    stang to a mn12.
    Randy
    Damn you guy's for bringing this up!! LOL!!!
    Now you got me wanting to do this! Like I dont have enough to do as it is. I know how to take care of the wheel wells, its called WHEEL TUBS!!! YEAH!! Contacting Kenny Brown is a good idea Randy when do you think you might hear something from him????
    NYC
    17,431
    Already looking into getting stronger shafts made at stock SC lenght..Hey Doug talk to fred yet?":O)/..If Not Im going to pester him somemore
    Sep 2002
    Effingham.IL
    5,011
    I think if I could find a 03 cobra in the junkyard that I could buy .
    I would try and just swap the motor and hole drive train.
    A blown mod motor and a narrowed rear end sounds nice.
    RANDY
    Oct 2002
    Indiana
    1,176
    dirtybird-
    will be heading to my local yard to pull the interior for my car-they have a 98 LSC sitting there-I believe that the IRS parts are there and in good shape.
    If you need the parts, let me know.
    Forked River, NJ
    2,092
    Randy
    The Cobra arms can't be used on the SC subframe.
    1.3 x 2 = 2.6
    Forked River, NJ
    2,092
    No Damon, I haven't had time. I'm home today, I'll try to give him a call.
