kenewagner
I will soon be swapping the rear end in my 93 SC automatic for one with 3.73 gears. Are there balancing problems that can occure when hooking up the drive shaft to the new rear end?
Just bolt it up the driveshaft. Take a test drive and see if you have any driveshaft vibrations. If you find that you do have a slight vibration, just simply rotate driveshaft a ¼ turn. Repeat as necessary to get it balance.kenewagner said:I will soon be swapping the rear end in my 93 SC automatic for one with 3.73 gears. Are there balancing problems that can occure when hooking up the drive shaft to the new rear end?
