Results 1 to 15 of 18
Thread: what is needed to run a 17X9 wheel on my car
    Aug 2002
    Alabama
    110
    I am about to purchase a set of the 17X9 Cobra R reps off ebay for my 95 SC. Can I simply take off the old wheels and put on these. I am going to run Potenza 245/45VR 17's on the car. Are these wide enough. They shouldn't rub, right? I am not planning on dropping the car. Will it look bad? Thanks.
    Somewhere out there
    3,477
    Lightbulb Re: what is needed to run a 17X9 wheel on my car
    My car is the one that advertises the 17x9 Cobra R's on the Supercoupe Performance site, so I will give you my $.02
    1.) The tire size that you have selected is an EXCELLENT choice!
    2.) The wheels will look awesome on your car and you will not have to worry about anything "rubbing".
    3.) I see that you do not plan on lowering the car, and this could be an issue. I recommend a "1-1/2 lowering kit. I had my '91 lowered and it was awesome with the Cobras. I decided to put them on my unlowered '94SC and I had issues with creaking and crackling noises when I went in reverse and turned the steering wheel. I eventually took them off and put them back on the lowered car. The creaking and cracking noises went away when i went back to the original wheels.
    Another solution may be to take the car to have it re-aligned if you are not going to have it lowered.
    This may solve the mysterious noises that I experienced.
    You will love the appearance of Cobra R's lowered or unlowered!
    Frank Burrell
    Dirtybird91
    May 2003
    Topeka KS
    275
    Wheels
    I just put mine on this weekend. I have 17x9 cobra's with 255/50/17 Kumho 712s. On the 1993 up spindles you will need a 3/16th inch spacer made for the front. The bigger sized tire of 255 will fit the rim alot better than the 245 will. Also if you plan on lowering it, run a 255/45 and if not lowering like you said run a harder to find yet better 255/50 tire. My car is not lowered and in my opinion doesn't seem like it needs to be. I'll try to get some pictures up sometime to show you what it looks like.
    I noticed you said you are going to run 245/45/17's, If thats the case, I would definately lower your car.
    Oct 2002
    Lebanon, Virginia
    52
    Thumbs up Dirtybird's car......
    This is DB's car.....
    20,939
    I went with 255-45s on all four wheels and it looked good with stock springs and a little better when lowered. Recently I went to a wider tire on the rear 275-40-17s and plan to replace the fronts with the 245-45-17s for less rolling resistance, and a more agressive look.
    I think the 245-45s are a little to skinny for the rear tires and would suggest at least going to 255-45-17s instead.
    Jan 2003
    Victorville, CA
    1,379
    I'm running 255/45/17's on 9" Cobras front & rear.
    It's a '90, lowered 1.5" - handles great with a decent ride and no clearance prob's.
    Lee
    Aug 2002
    Alabama
    110
    Thanks to everyone
    Ok, here is the deal. I am now thinking of going withthese tires:
    http://www.tirerack.com/tires/tires....omCompare1=yes
    or:
    Take a look. Look at the ratings on the Bridgestones. Nice tread design too!! Whatdo you all think. If I go with these in the 50 series, I might not have to lower the car, right? But will they rub up front or stick out too far and make the car look "ghetto". I want a nice ride as I travel a lot so I really don't want to lower the car if it can be avoided. Maybe one day later when the car is not used as my primary car. Will I need spacers and if so where do i get them, the place who installs the wheels? Will these 255's make the car handle and corner any worse or better? That is a nice looking car. I want a hood like that. When I get done with my car, I will be joining this awesome club and posting pics of my 95 Mystic Blue 5 speed Beauty. To all: Thanks and have a great day.
    Tony
    Sgt/USMC Reserves
    San Diego/ UCSB
    234
    yes i can confirm that you will need a braket with the wheels you are getting, if yours are coming form OE. wheel distributors, sarasota florida???
    unless:
    BlckOnBlckBrd do you have the 13inch brake up grade?? where are your rotors from??
    if the answer to this question is no, then you will definetly need the spacers for the front wheels only. If the answer is yes, then you may not need the spacers.
    i don't know where to get spacers from, i made my own.
    If you end up not needing the spacers, PLEASE let me know, i'm very interested. You can email to jkanterakis@umail.ucsb.edu or through my profile
    these are the wheels i got. they look sweet, i have the painted style. I run a 255/45 series tire and the car totally looks fine NOT lowered. i didn't look at the tires you had posted for selection but i can tell you i have the BF Goodrich g-Force T/A KDWS 255/45/zr17. i got them installed for about $145 a tire.
    yes, your cornering ability will increase.
    jim
    May 2003
    Topeka KS
    275
    Pics
    Sorry about the bad pics, they were taken from a video as I don't have a digital camera, just a digital camcorder
    This is my car with 17x9 Cobra R's with 255/50/ZR17s
    May 2003
    Topeka KS
    275
    Front...
    May 2003
    Topeka KS
    275
    Better shot of rear...
    May 2003
    Topeka KS
    275
    Front and rear...
    San Diego/ UCSB
    234
    BlckOnBlckBrd
    dam looks sweet. you got the painted ones too.
    any way, trying to clear something up here.
    first what year is your car, and also do you have a front brake upgrade kit, or do you still have the stock brakes,
    if you upgraded where did you get the rotors you have. trying to figure something out for the wheel spacer needed.
    thanks
    jim
    Jun 2003
    Bellevue, Nebraska
    204
    I have a 94SC auto and I have 255/45/17's all the way around. he's right...all you need are spacers in the front. no other modifications needed. most wheel/tire shops have them or can order them within a day or two. You can also find them online. Autozone might even carry them.
    May 2003
    Topeka KS
    275
    My car is a 1993, and I have the stock brakes... for now. The wheel will clear the suspension without a spacer, but it is impossible to clear with a wheel weight for balancing, so that's why you need a spacer.
