Results 1 to 15 of 27
Thread: check out my homemade cold air intake...
    Jul 2003
    South Central Los Angeles
    3,538
    hey check out my home made cold air intake...
    all it cost me was about 6 bucks and around an hour of labor.
    let me know what you guys think...
    i still need to modify it a lil.. ima make it go behind the front bumper so it can really pick up some cold air... latez
    Tulsa, OK
    767
    Looks good. Needs a Viagra sticker on the side.
    New Jersey
    1,335
    Get the Magnum Powers cold air divider
    And this will help you. It allows you to get cold air and seperate the engine compartment heat from the air filter.
    Don
    Illinois
    2,838
    cold air intake
    Looks like a good idea I have the fancy chrome one with the blue rubber that goes into the fenderwell I will probably switch to a 3 inch piece of duct pipe like you did know anybody that wants a fancy intake system?
    Oct 2002
    Des Moines, Iowa
    735
    Not too shabby for 6 bucks but it's not a cold air intake, it's a hot air intake. It's not a cai until you mount it in your fenderwell or find a way for it to suck up cold air.
    Sep 2003
    Sarasota, FL
    63
    lol viagra... does kinda look like a..... haha... dude whered you get the pipe from? like home depot or something? not a bad idea. saved you about 100 bucks... right on!
    May 2003
    41
    Nice i guess, but why is what i want to know ?
    Is that the stock MAFS ?
    And how much was that filter ?
    Jul 2003
    3,538
    well the filter was 12 bucks from some shop here by my house... and as for the MAF it is not stock. Its one of those ones that have like a straight tube down the middle going up and down ... i removed the center tube for more airflow...
    May 2003
    41
    How much was the new MAF ?
    Imperial, MO (near St. Louis)
    4,343
    As in a 70mm MAF from the 94+ cars?
    -Rod
    Illinois
    1,744
    Looks like a nice setup; and certainly about the lowest price I've ever seen anyone make an intake for. Only thing about that MAF.. I have heard that removing the interior core disturbs the flow of air inside the unit causing turbulance, and hence bad air readings. This actually makes it worse than an unmodified unit. See the articles at this site for more information about this. I think there are several cheaper options to buying a new aftermarket MAF sensor if you want to upgrade.. especially for older cars.
    Jul 2003
    3,538
    hey well i guess from a 94... cuz when i first saw it i thought mines was like a cheap one.. but then i read and saw some dudes instructions on how to remove the thingy.. and i did it...
    well removing that center piece doesnt give me turbulence.. the only time ive had turbulence was when the filter fell off in the freeway... and im guessing it caused the MAF sensor to just give up and the engine died... well dont know dudes... anything else?
    South Florida
    471
    I'd hate to break it to ya, but the clamps on the MAF and TB are useless on the exhaust...err intake pipe...err tube.
    Somerset, Mass.
    632
    MN12KID
    Good call - I didn't even look that close!
    Aaron
    South Florida
    471
    Yeah, the only thing he can hope for, is that nothing wobbles loose, with such a setup. He can resort into getting rubber fittings, for each side. With those, at least he'll be guaranteed more of a secure/snug fit.
    Another thing I noticed, that was disturbing - the air filter is mounted INSIDE the MAF ring, not OUTSIDE. This will restrict some incoming airflow.
    No offence, but I think he'd get better overall results, from the stock air tube.
