Thread: climate control system
    battle creek, mi
    86
    Question climate control system
    when I put the fan switch in the auto position for heat in the morning, it should not activate the fan until the temp is at desired temp that you have adjusted it to on the display. But mine is coming on full blast when I put it in the auto position immediately without waiting for the desired temp to be reached.
    Toronto, Ontario
    172
    I believe that the fan will run on full until the temp. gets to the setting then cycle at different speeds to maintain the temp. after that.
    battle creek, mi
    86
    Hmmm, I thought the purpose of that switch was for the air not to come on until the desired temp is reached. I'll see if I can dig up the manual. Thank you
