Results 1 to 2 of 2
Thread: Need some help,, can someone send me pics of --->
    Oct 2003
    Merrillville, IN
    Clutch pedal assembly under the dash?? and possible where the slave cylinder is mounted and where the resivoir is also mounted?
    I'm converting my 90' Thunderbird from Auto to Manual and looked under the dash and there are no holes or mounting points for the clutch pedal.
    Brad M
    Jan 2003
    Have Fun!!!!!
    The res is located on the drivers side fenderwell next to the mastercylinder. The slave cylinder is located on the transmission, inside the bell housing on the shaft, and you'll have to mount that peddle some how.
