Page 1 of 9 12345 ... LastLast
Results 1 to 15 of 132
Thread: Making a custom lower intake
    Thorold, Ontario, Canada
    2,432
    Thumbs up Making a custom lower intake
    I am gonna try and make a lower intake to fit the SC roots blower to split port heads. The split port heads came ont he 99+ mustangs and 97+ F150's. The spilt port runner design netted 40 HP gain on the N/A V6 mustang motor. I have seen these heads net a 75 HP gain on a supercharged motor. So I am curious to see how they will affect power on the roots blown motor. I am basically gonna copy the original single port lower but have the end flanges have the openings for the split prt heads instead. Morana started one a year or two ago but never finished. I finally got some split port heads and intake to work with. Here are some pics.
    The Fuel rail shoudl not be a problem as I will use the F150 rail reverse mounted. Just gotta get the blower high enough to clear it. I cut up the F150 intake to see what it looks like inside. The cooling channels are different, on the single port they run straight across the front of the lower intake, but on the spilt port heads they run down the center of the lower and across at teh front and back. On my intake I will just ahve it run across the front, as the rear opening are blocked by the gasket anyways and the coolant will just heat the intake anyways. If the stock SC lower has it just across the front then this one will be fine.
    First I cut the flanges off the lower so I can use them as templates for making new ones.. After this I will make a lower plate for the intake, then fab up the cooling channels and then thermostat housing section, then the top level for hte blower to sit on and the rear opening for hte air to come in. Here are the pics.
    Flanges cut off and intake split down the center
    Flanges
    Thermostat housing removed
    Center section split apart
    2,432
    Better view
    Close up up coolant channel and EGR channel, the EGR things in the secondary runners are just stuck in the holes, so they can be pulle dout easy, they just have 4 little tabs holding them in place.
    Fuel rail mounted
    Tejas...home of Stevie Ray Vaughan
    1,748
    I've looked for a set of heads/intake locally but none around that are wasted enough to get a good deal on. How about restrictors in the front water passages on the heads so more water will get drawn from the rear?
    That way, the rear of the head would get a little better cooling. Currently, there's not a whole lot to encourage the water to the rear of the block & up into the heads. With restrictors there might be more flow in the rear(?)
    This makin' any sense?
    'bird
    2,432
    Originally posted by V6Sprout
    If you look at these three pics it will show the water passage. In the 3rd pic, the water passage comes out the head at the front of the block right below the second port. If you look at the rear water passage the intake gasket blocks it (right below the last port, black area on gasket). Now looking at the lower intake you can see how the water channels from the front right to the back of the lower intake, but again the intake gasket blocks this and doesn't allow any coolant back there, but there is a small pin hole in the gasket to allow a very liittle amouint through. When I amke the lower I thought about just having it run across the front since it can't get through the back anyways. What are you thoughts here?
    Also having the coolant passage go through the entire lower intake wouldn't this heat back up the incoming air that the IC just cooled down? This is another reason I thought of just having the coolant passage go through the front of my new lower intake.
    Give me your suggestions and ideas guys, I want to make this a well functioning lower and possibly make more in the future for others.
    Imperial, MO (near St. Louis)
    4,341
    If you do, consider me very interested. I sure wouldn't mind throwing a spare M90 on my splitport 94 LX.
    -Rod
    2,432
    humm, this is gonna be a little harder then I thought, but I am still gonna do this. The fuel rail I posted above doesn't look like its gonna work, sits too high, the spot thats the problem is the area where it goes under the blower, on ours the rail dips under the blower, so I would have to really raise the blower up to clear this rail, plus at the back it looks like it owuild interfere with the rear intake, hummmm.
    The other problem I am gonna have is the mounting of this lower intake, the mouinting holes are not all across the top of the head like on ours, they are staggered, some are at the bottom of the head. I may have to make a removeable lid to the lower intake in order to access the mouinting bolts, then make a mounting lid that seals up, not too hard just extra work, DOH!
    Like I said before though, its a slow process and hopefully I can get it to work.
    NYC
    17,430
    As far as cooling in the rear of cyl..I tap the manifold where the water passages are for flow acorss from head to head..Works on teh ford V8's
    4,341
    V6Sprout,
    I don't know if this will help you, but I used a E-150 fuel rail when I did my splitport swap. I had to make two brackets to mount the rail to the lower intake because two of the mounting holes didn't line up with the splitport lower intake holes, but other than that it worked out great. I believe that it sits lower than the rail you're working with.
    -Rod
    San Bernardino, CA
    4,523
    I can see the benifit of this swap on a n/a motor but dont,
    see how its going to add to the hp on a supercharged motor,
    the head still has one valve for intake and we have not reached the flow cap on our current heads intake ports.
    as the valve can only flow so much air ,
    I beleive the purpose was to creat high velocitys on intake port,
    for na to ram air into cyl,
    and atomize fuel in a high velocity stream. but please explain how this n/a technologies will help on a pressurized motor ,
    am I missing something here?
    2,432
    I don't know for sure it will help, but I do know poeple running these heads on mustangs with power adders are making HUGE HP. We have one guy who made a custom twin turbo setup and ran 11's on the stock motor, no mods to the motor except the turbo and injectors and MAF and slightly larger TB but still smaller then ours.
    I also swpped these heads onto a Vortech mustang and he gained 75HP from the swap. Now with the way the lower intake on our motors is, there are no real runners like on these intakes, so it may not have any effect at all who knows, but we'll find out after the swap. The project is more for fun to see if I can get it to work and see if there is any benefits out of it.
    San Bernardino, CA
    4,523
    Imk not being negitive I was just wondering I too have looked at them with interest and i will be keeping a eye on this subject,
    too bad ford didnt make any four valve cyl heads. for our 3.8
    or overhead cam we would be in hp heaven.
    NYC
    17,430
    Perhaps a pancake type manifold for the split port will do..Much like our factory SC intake..Would be easier to fabricate..Good ;uck!
    2,432
    Manny you brought up a good point, I knew you were not being negative but more inquisitive (sp?)
    Damon, I plan to make it a pancake style like the factory one, but I have to take into consideration the cooling ports are placed farther back on htese heads, not quite at the front, and the mounting holes are staggered, some at the bottom of the head. I hope to make a removable lid on the intake to allow access to these bolts, just gonna take a bit more planning thats all. A custom fuel rail is looking a lot easier then finding a factory one to use. I heard the E150 rail may work so I"ll check into that as well.
    Kepp you ideas coming folks, I welcome any advice, all ideas will be appreciated, good or bad, let me know what ya think.
    NYC
    17,430
    The cross over part of teh rails can be replaced with longer peices if thats holdin ya back
    2,432
    I firgure I can worry about the rails later, probably do like what you suggested, make custon end piece to attach each rail to each other.
