Results 1 to 15 of 18
Thread: A question for you Supercharger Guruís
    Oct 2003
    Baltimore MD
    16
    I have a question for you Supercharger Guruís. I am working on a custom supercharger project using a supercharger off a Supercoup. The supercharger I bought is new and did not have a pulley attached. I have since obtained a pulley and am ready to install.
    My questions are as follows:
    1. When installed, is the pulley flush with the end of the shaft? If not, how much does the shaft protrude past the pulley?
    2. If I freeze the supercharger and heat the pulley to 500 degrees, can I drive it on (gently) with a hammer or does it have to be pressed on? If it does need to be pressed on, does the nosepiece need to be removed to do so?
    Any information you can give me will be greatly appreciated.
    Thanks.
    Sep 2002
    Outside of Chicago
    1,075
    Wink Hope this helps
    Keeping the pulley hot and blower cold is a cool idea, but I hope you got some good gloves. I just wobbled the pulley on to a certain point, and then used the nut to tighten it on the rest of the way. I had to use vise grips to hold the pulley while tightening the nut also. Some choose the easier and more pricey route of buying a supercharger pulley installation/removal tool.
    Oct 2003
    Baltimore MD
    16
    pearl95sc, thanks for the reply.
    After reading your post I did some searches and it seems I've got a different snout on my blower then the ones I see in pictures posted here. The shaft appears to be just as long but without a threaded end. The shaft is the same diameter since the pulley would be a tight fit. Also everything else from the Supercoup bolted right up. ????!!!
    Anyone here have a blower with a pulley that is pressed on (no nut)?
    Zionsville PA
    443
    You must have a GM blower they are pressed on. Try here for more info
    Zionsville PA
    443
    H-Town Tejas
    2,891
    Does it have a keyway and a nut, or a bolt and no keyway?
    Does it look like this? Early Ford M90
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=43808
    Does it look like this? Late Ford M90
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=33741
    Does it look like this? Late GM M90
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=33617
    Does it look like this? Early GM M62
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=42604
    Jeff
    Oct 2003
    Baltimore MD
    16
    J57ltr,
    It looks like an early Ford M90 but without the threads for a nut. It does not look like a GM M90 because the intake port is the same as early Supercoups and mine will mount the 3.8 top hat just like the Supercoup.
    Seems to be some kind of hybrid.
    My concern is if it will damage the nosepiece bushings/bearings if I drive the pulley on gently. I don't see any way to press it on without removing the nosepiece.
    I am not worried about the pulley coming off since this is the way most M112 blowers mount their pulley. Since this is a custom install on a 4.6 engine, I can adjust for any differences in the nose length when I fabricate the mounting plate.
    H-Town Tejas
    2,891
    Does it have internal threads? Try to post a pic.
    A GM M90 snout is longer and can be made to fit. But a pressed on pulley needs just that, a press. Hammering will damage the bearings.
    Jeff
    Oct 2003
    Baltimore MD
    16
    J57ltr,
    Thanks. I'm pritty sure the shaft is solid (no internal threads). I will try to get a picture up in the next day or two.
    If I remove the nose piece, will I have access to the back of the shaft so I can press it on properly? Also, anything I need to know when taking off the nose piece?
    H-Town Tejas
    2,891
    Post a pic B4 you take it apart. Lets see what it is.
    If not I will take some pics of the GM/Ford/Jag SC snouts I have.
    Jeff
    Oct 2003
    Baltimore MD
    16
    J57ltr,
    Yes I will get pictures up before I start working on it.
    Thanks.
    2,998
    This thread has some pics and more info on M90 blowers that someone else had with no threads on the shaft:
    http://host.sccoa.com/forums/showthr...threadid=29944
    H-Town Tejas
    2,891
    Here are a couple of pics. Left to right Jag M112, Ford M90, GM M90. The GM snout was turned down on the end for a smaller pulley (or so I was told by the previous owner).
    H-Town Tejas
    2,891
    Here is a closer view of the M90's.
    I'm betting that George's thread he found is the answer.
    Oct 2003
    Baltimore MD
    16
    It looks just like the early Supercoup M90 except it looks like someone cut the threads off. I know this was a test unit for Eaton Quality Assurance and has never been on an engine.
    It was broken in at Eaton, tested for QA then rebuilt and sold as used. Perhaps they removed the threads when they were testing or perhaps the guy who had it before me???
    How hard would it be to switch out the pulley shaft and how would I get one??
    I has a manufacturing tag as follows:
    The ASSY number EA-17265-5
    S/N 22128
    Production date 4-2-92
