Results 1 to 6 of 6
Thread: Power steering problem
    The steering is very hard on my '95 SC (130,000 miles) when at a stop. Revving the engine doesn't change the symptoms. Only getting the car moving helps. Fluid level is fine, as is belt tension. Is the pump going bad, or the steering "box" itself?
    Oct 2002
    Indiana
    1,176
    Recently done anything that required removing the pump?
    Sounds to me like air in the system
    Feb 2003
    Ames, IA
    253
    turn your steering wheel lock to lock a few times, this is suppose to get air out of the system.
    -Thomas
    Dec 2003
    Mineral Wells, WV
    51
    Is the pump noisy? If not it might be time for a new rack.
    Haven't had the system open at all, or done anything to it. No noise coming from the pump or anything, just hard to turn when at a stop. I'll try the lock-to-lock thing.
    Thanx guys,
    Mike
    Oct 2002
    Indiana
    1,176
    Need to have the cap off when you do it-and monitor the level of the fluid.
    Easier to bleed when the system is warm-especially if you live in a cold climate.
