Results 1 to 15 of 16
Thread: Any interest in urethane rear spring isolators?
    Forked River, NJ
    2,092
    Question Any interest in urethane rear spring isolators?
    One of the aftermarket companies has just released a urethane spring isolator kit for the 99+ IRS Mustang Cobra.
    Why do we care? Because the lower isolator for the Cobra is the same part number as both the upper and lower isolators on the MN-12 platform.
    I told them this, and they're sending me a set to try. I'm confident that they'll work, and eliminate one of the problems in the rear suspension as the stock isolators don't last very long.
    I'd like to be able to tell them that there's a market for this kit, priced below $40, so post if you'd be interested.
    Thanks
    Oct 2003
    Albuquerque, NM
    1,609
    Sounds good to me!
    Feb 2004
    cleveland, tn
    100
    I would be interested pending feedback on results after putting them on.
    Russell
    Earth, Terran System, Alpha Quadrant
    52
    Thumbs up THanks
    People who research stuff for our Birds are AWESOME. You are one of them. Thank man. Peace.
    I would be interested IF they are dimensionly the same as new stock pieces. Once you get them PLEASE measure the dimensions and post them so I can compaire them. My rear suspension is totaly disassembled right now so I have parts ready to compaire things to. (in case yours is not apart yet)
    Jan 2004
    Lock Haven, PA
    16
    I would take a set!!!
    urethane is the only way to go. I replaced all the bushings in my Montero and it rides like a new truck now
    Edmonds, WA
    394
    Sign me up especially since I'll be lowering it soon.
    SW Michigan
    2,222
    Looking for a cure for HWH for 15 yrs!
    I want to talk to you. [email protected] (that's lower case QTM.NET)
    I believe that the source of Wheel Hop in Ford IRS cars is: The Large Squishy, rear sub frame isolators. Is this what you are talking about?
    LETS TALK!!!!!!!!!!!!!
    68COUGAR
    Forked River, NJ
    2,092
    Re: Looking for a cure for HWH for 15 yrs!
    68COUGAR [/B]
    No, I'm talking about the coil spring isolators.
    BTW, I don't have wheel hop. A 1 3/8" sway bar, air bags, H&R springs, Tokico shocks, MN-12 knuckle bushings, and DR's cured it for me.
    SW Michigan
    2,222
    Another AOD guy
    Well, All of us 5-spd guys know what Doesn't Work! Hopefully I'll find something that DOES work!
    5-spd 68COUGAR
    ______________
    Forked River, NJ
    2,092
    Re: Another AOD guy
    5-spd 68COUGAR
    ______________
    Excuse me? I've had 5 speed SC's since 1990
    SW Michigan
    2,222
    Apologize
    I apologize! Most people who respond are AOD guys. I responded before I saw who you were!
    What do You think will fix HWH?
    Serious 68COUGAR!
    SW Michigan
    2,222
    Parts is Parts
    My 1 3/8" F&R sway bars helped through the corners, but DO NOT help at the strip. Please do not quote solid axle dynamics, because they simply do not apply to IRS!
    IRC: Two schools of thought here.
    Theory (1) With the suspension in soft, disconnect the rear shocks. Then put the front in FIRM. Theory: The rear will squat & the front will raise!
    Theory (2): Put the suspension in HARD, then disconnect the Front shocks. Theory: The front shocks will stay soft, while the back shocks are hard. Result is that the rear is stiffer & doesn't hop, & the front responds to the weight transferr.
    Which thinks you?
    68COUGAR
    Forked River, NJ
    2,092
    With my SC, 2 is the answer.
    I really don't want an argument with you. I know what works for my cars, and I've got the numbers to prove it.
    And, this wasn't the reason for this thread in the first place.....
    Mar 2003
    St. Petersburg, Florida
    1,177
    any feedback on these? I need to get a set as im putting some springs in soon....where can I pick some up?
