bigcletus94
I was asking about this a little while ago and it is still a problem I am having. I recently put in the stock 97 degree Tstat and cleaned my MAF sensor with electric cleaner and a Q-tip.
It will idle fine until it gets warmed up, then it will idle at 500 rpm and the low batt indicator will light up very dimly. If I turn on my heater, it will bring up the idle enough to make the light go out. It gets really bad like it will die if I am turning the wheel when the rpms drop. I don’t think I have a vacuum leak because it is only a problem after I have been driving for a while. Any idea what could cause this? Thanks.
