Results 1 to 15 of 24
Thread: A dingleberry hone?
    Norcross, GA
    3,306
    A dingleberry hone?
    Indeed, I'm now the owner of a 3" dingleberry hone. Officially called a cylinder flex hone it's dozens abrasive balls on wire ends attached to a spiral shaft. After just receiving and installing an Extrude Honed lower tube on my drag racer, I took the metal cutting tool/die grinder and the dingleberry hone to the set going onto my red 90. The 2 tools really ground out the inside of the tubes and I was able to go quite deep into them, aluminum chips and black dust everywhere. They came out pretty good, almost as much as the Extrude Hone process did for as far as I could reach with it. I wrapped the new tube with thermal tape and painted it before installing. I did 3 tubes last night and made a total mess but I'm real pleased with the results.
    Norcross, GA
    3,306
    And here's what I did it with. The compressor ran the whole time but kept up the air pressure no problem. Glad I got ear plugs!
    NYC
    17,430
    Now if you can attatch that to a flexable line you can get all teh way in their
    [beavis and butthead]you said dingleberry[/beavis and butthead]
    Dec 2003
    McAllen Tx
    180
    "dingleberry hone".........sounds painfull
    Howell, NJ
    1,707
    Where did you get this dingleberry hone that you speak of?
    SCCoA Member# 1786,
    1990 SC, AOD, 193k, Twilight Blue, bought in 1994, 1.7 AR tuned by Dave Dalke
    1994 SC, 4R70W, 139k, Teal Metallic, bought in 2014
    2014/2016 Carlisle 1st Place Winner, 94-95 SCs
    2014 Carlisle SCCOA Doug Fraleigh Best of Show Modified Trophy
    Norcross, GA
    3,306
    I bought it at NAPA. They come in 3" to 4" diameters and in 2 different lengths. $68 and up. The little balls stand right up when it spins. A die grinder is too fast and a high speed air or electric drill works best. It goes right around bends in the tubing and a flexible extension will extend it's reach.
    Feb 2003
    Wichita, KS
    1,653
    Wanna do a set for me?
    Norcross, GA
    3,306
    I'll e-mail you about it.
    Howell, NJ
    1,707
    What grit hone did you use?
    Norcross, GA
    3,306
    All they had was a 120 grit in all sizes.
    San Bernardino, CA
    4,523
    thats what I used on my exh manifolds and ic tubes before i had them extrude honed .
    Oct 2002
    Lincoln, NE
    2,062
    How will that work on the lower???? Just curious if it is even worth trying. I've been doing the same thing with a spare upper that I have laying around...The only difference is that I've been using a dremel! So needless to say, the going is slow, and I can't get all the way in there yet. You can email me too on the price you would charge to finish what I'm not too sure if I will or not.
    Howell, NJ
    1,707
    Not me- I'm going to have a go at it myself.
    As soon as I read "dingleberry hone" "cylinder flex hone" and saw a picture of it, I just had to have one!
    Just curious- would it help cut down the mess if you stuck a vaccum hose in one end of the tube while you worked on the other end?
    Norcross, GA
    3,306
    Yes, a vacuum would be good. The grinding tool took out the most metal and makes a lot of filings. The hone makes a dust but if you use a WD40 kinda lube it makes an abrasive mud instead of dust. I was surprised as to how far I could reach with die grinder and hone. I'm having trouble getting the teflon tape to seal. It keeps mushing out and not sealing. So I went in closer and put another layer outside of it and made it wide enough to cover the whole surface. I hope this gets its this time. I can tell when the seal breaks because it misses real bad, usually in 3rd when I punch it but not in 1st or 2nd. I really anxious to try them out. Snow/sleet/freezing rain tonight but 60 and sunny on saturday for the test & tune.
