Results 1 to 9 of 9
Thread: 750 HP SC engine
    750 HP SC engine
    Cosworth GBA 1.5 litre V6 F1 engine
    Condition: Very Good
    Price: £15000 GBP United Kingdom Pounds
    Description
    We Have available three (3) of these used ex F1 engines built around 1986, they are the GBA 1.5 litre V6 twin turbocharged engine. They originally produced 750 BHP and can run 1000 BHP with boost and fuel adjustments. They come complete with injectors and ECU's but it would need to be stripped down and checked before running. All other components like manifolds, turbos, flywheel and clutch are all present. £15k is for EACH engine, not for all of them.
    History
    produced in 1986, the 120 degree v angle engine ran in Formula one in a Benetton in 1987 using "rocket fuel" to attain 1000 BHP
    Technical Data
    Weight: 200+ lbs
    Engine
    Engine Builder: Cosworth Racing
    Manufacturer: Cosworth Racing
    Type: Formula One
    Displacement: 1497 cc
    Horsepower: 750 - 1000
    Torque: unknown
    Induction: Forced air via twin turbochargers, Fuel injected
    Heads: cast aluminium alloy, 4 valves per cylinder
    Block: Cast aluminium alloy
    Main Caps: unknown
    Crankshaft: billet type
    Connecting Rods: unknown
    Pistons: pressure forged
    Camshaft: unknown
    Valves: 4 off, poss. titanium?
    Valve Train: unknown
    Clutch: unknown
    Pressure Plate: unknown
    Flywheel: unknown
    Exhaust: tubular steel
    Total Time: unknown
    Races: 1
    not much known about these engines, they were run in a race, and removed from the car, they may have been rebuilt, but have been in storage for a number of years. They can be viewed if required by appointment only at our premises in Northampton.
    Spares
    crank sensors and a few seals etc.
    some parts have been remanufactured
    by various companies, we can reproduce
    pistons etc. if required
    With a engine like this any SC whould be awsome
    hey is setup would work great
    anyone want to step up and try it on a SC engine
    Oct 2002
    Indiana
    1,176
    for $28,000 you could have someone like Saleen or Coy Miller build you a motor that would have about the same power-but with a h*** of a lot more torque!
    They're F1 motors-you wouldn't get much of a launch with a 4000lb car like they do with the F1 cars(1500lbs), and the power band is up around the 10,000RPM range.
    Nov 2002
    Columbus, Ohio
    6,923
    God that thing has to be a nightmair to work on!
    Shane
    Jan 2003
    Allentown, Pa
    1,031
    but gorsh... it sure is purrtyy paw... mabye one day... hehe
    Nov 2002
    Cresson, TX (DFW)
    1,320
    So who's Pantera equipment or whatever is this?
    Gotta love those F1 engines but I would need the transaxle to go with.
    Hewland NLT Sequential 6-Speed
    Serial Number: HE54
    Condition: Concours
    Price: $20000
    Description
    -Brand new 4/02 never used or installed. This unit was spec'd and purchased from Hewland as a team spare.
    Transmission
    -Manfacturer: Hewland
    -Type: NLT Sequential 6-Speed
    -Gears: 1st gear only in case, ratio:12:36
    -Races: new
    Rear End
    -Manufacturer: Hewland
    -Type: integral with gearbox
    -Ratio: 10:31 CWP
    -Differential: Powerflow diff
    -Races: new
    -Magnesium case, 80x80 ramp angles
    Spares
    none
    Hewland DG300 Lola T332 Complete Rear
    Condition: Good
    Price: $18000
    Description
    Lola T332 F5000 DG300 Complete rear end including uprights, brakes, callipers, drive shafts and Koni Shocks. Comprehensive gear ratio’s and more.
    Transmission
    -Type: DG-300
    -Complete rear end including uprights, brakes, callipers, drive shafts and Koni Shocks. Comprehensive gear ratio’s and more.
    Spares
    -none
    Nov 2002
    Cresson, TX (DFW)
    1,320
    Thanks, but looks like they have what I need at my price over at OJ Hanna at MSR.
