Results 1 to 5 of 5
Thread: Loud cooling fan?
    Maumee, Ohio
    275
    Loud cooling fan?
    Lately my fan is making way more noise than it used to.
    It does run all of the time on low speed. It does not make a bearing noise or anything just overall allot louder.
    Is the motor going bad?
    If it is a bad motor, what is the best deal on a replacement?
    thanks
    Ron
    790
    Hi Ron:
    Seimans makes replacement motors for SC rad fans for about $100.CDN here, so it should be less there. Good luck
    SC
    35
    I had my fan burn up and burn some wires close to the fuse block. I got a replacement fan at Autozone for about $100, but could not get the old motor out of the fan. I would replace the fan motor if I was you, to avoid if it does burn up, burning up the other wires
    Maumee, Ohio
    275
    Well the motor eother finally fried or blew a fuse.
    I found a replacement from Murrays, a Seimens, for $69.00. So one more project for the weekend!
    790
    When I did mine, I found that the blades part was pressed on with a clip to keep it there. The clip came off easy but I had to soak the metal sleave with rust buster and press the motor shaft out. Good luck
