Do you need to drop the oil pan to pull the timing cover? Do you need to pull the oil pump and cam pos sensor to pull the timing cover?
Got my BHJ balancer to replace my broken stocker and decided to change the timing chain and tensioner while I had things apart. Got all the bolts out, but it's not coming off. I didn't use much force, don't want to break anything(other than the water pump bolt I already broke). The cover is loose but it's not going anywhere.
Any suggestions?
Thanks
Mike
Any suggestions?
Thanks
Mike
