Wzenheimer
Here is the finalized list of the street stock rules. Please vote accordingly.
Street Stock Class
Any modifications not specifically listed in these rules will not be
allowed.
1. Exterior: body kits, wings, spoilers, fender extensions and all
other cosmetic body modifications are allowed. Such modifications must
not serve any other purpose. All original body panels must be present
and function as originally designed.
2. Interior: Stock interior must be retained. Panels may be modified
for any cosmetic reasons but must not be removed. All factory equipment
must be retained including but not limited to A/C, radio, power seats,
power windows, etc.
3. Wheels/tires.
a. Tire width is unrestricted however rubber must not extend past stock
bodywork. Tires must be of radial construction and have a UTQG
treadwear rating of 120 or higher. Competition tires prohibited. Space
saver tires prohibited.
b. Wheels are unrestricted provided they do not protrude from the body.
4. Engine.
a. Exhaust must include catalytic converters and mufflers. Must be of
reasonable volume and must exit under the rear bumper. Headers are
allowed.
b. Intake for this purpose includes everything up to and including the
throttle body. Stock throttle body must be retained. There can be no
openings made in the body for the purpose of air intake (scoops, ram
air, etc) Intake tubes such as they fit the above requirement are
unrestricted. MAF meters are unrestricted.
c. All stock engine accessories must be present and operational (belts
may not be removed nor short belts used). Aftermarket pulleys are
allowed and unrestricted.
d. Engine modifications (valve covers to oil pan) are not allowed.
e. Supercharger modifications are not allowed. Raised stock-type
outlets permitted.
f. Intercooler fans are permitted. Icing of the IC or any other
artificial cooling methods prohibited.
5) Transmission and rear end.
a) All stock IRS components must be retained. Gear ratios are unrestricted.
b) Clutch/flywheel must be stock type replacements, Torque converters must retain stock stall speeds and function. Shift kits allowed. Line locks not allowed.
6) Fuel. Pump gas required (max octane 94). No fuel additives or oxidants (nitro or alchohol based) allowed.
7) Computer tuning allowed.
Street Stock Class
allowed.
power windows, etc.
3. Wheels/tires.
4. Engine.
allowed.
outlets permitted.
