Shooter_Jay
What an exercise in patience and determination! By the way I"m 6' 210 lbs so I don't have the skinny arms they recommend! Wow that passenger rear plug is a real bitch! Got a bit scary too...test driving it after I blew a plug right out of the hole!!!!!! I thought I was screwed. I figured it destroyed the threads in the head and was probably that passenger rear plug 'cuz it was tough to be sure it was in all the way since I could barely even reach the damn thing! Turns out it was the one next to it which is much easier to get at, and kick-***, there was no damage other than the plug electrodes were touching each other. Regapped and reinstalled and then...it was running smooth then stalling and making a pshshshsh sound after it stalled...wierd. After a few restarts it started running fine. Test rode it and it seems fine now. On the bright side I got my money's worth out of AAA. 2 things I'd recommend adding to the instructions...on the passenger side if you use a bar to pry apart those hoses you can get in there pretty good, figured that out on the reinstall...and 2, put a little of that dielectric grease on the rubber part of your spark plug socket wrench so you can actually get the damn thing off the plug after you screw it in! Anyway, I feel like I just climbed mt everest or something, what a struggle!
