Results 1 to 7 of 7
Thread: Adjusting E-brake cable
    Feb 2003
    Montgomery, Alabama
    234
    Question Adjusting E-brake cable
    How do you adjust the tension level of the emergency brake and where?
    Thanks.
    Chris
    Feb 2003
    Murrysville, PA
    1,276
    Between the rear gears and the rear bumper you will see a bicycle brake looking cord going to each wheel. In the middle you will see a spring, the clip that holds the spring inside of it is what you need to detach from the little bar with divots in it. Unclip it and move it so its nice and tight then clip it back on the bar with diviots on it. Thats it.
    -Tesla Model 3 Performance-
    -89 White 5-speed, 450HP 430TQ-
    My garage
    Oct 2002
    Covington, WA
    491
    What if that doesn't fix the problem? I did that so now I have tension in the line but when I apply the E-brake and put it in neutral I still roll down the hill. What else should I check?
    Apr 2005
    44
    whats good
    how are your pads?
    Oct 2002
    Covington, WA
    491
    new pads all the way around and it is only the E-brake that isnt working
    Nov 2002
    Vancouver B.C
    154
    calipers
    well its hard to tell if your calipers are siezed wen u do regular braking because most of the braking comes from the front...i would check the calipers
    Oct 2002
    Covington, WA
    491
    That was what I was thinking but I was hoping for something easier.
  1. TCCOA TV Cable Adjustment
    By duanemyhre in forum Technical Forum
    Last Post: 02-01-2012, 11:55 AM
  2. Continued ABS woes (and others)
  3. Replies: 7
    Last Post: 09-04-2002, 12:08 PM
