Digitalchaos
Has anyone ever been able to bleed the ABS section of the TM IV w/o the expensive braker box? If so, how did you do it? Can wires be used to complete any of the circuits at the ABS harness to replicate the signal from the braker box, similar to checking for codes from the EEC IV using a jumper wire?
This is in effort to diagnose my weak brake pedal. I have already tried bleeding the system normally several times, but this does not evacuate the air from the ABS section on the Mark IV, and it seems that air in this section can affect normal non-abs operation.
Thanks for any help..
