Results 1 to 15 of 21
Thread: Pros an cons Gunk engine flush in 5min
    Oct 2003
    McHenry,Illinios
    73
    Question Pros an cons Gunk engine flush in 5min
    I was at the auto parts store and found a can of gunk engine flush in 5 min and I wonder if I could reck my engine. It says pour it in with the old motor oil and run it for five minutes and the do an oil change. It says on older engines you should the drop the oil pan and clean all the crud out of it. It supposed to clean the engine out real good uncloging lifters breaking up carbon deposits the works. My Sc has 160000 on it and before it broke I was way over due for and oil change (my bad) so I'm sure it's pretty bad but I don't want to destroy the engine. I'm thinking it would be a bad idea to use it so I probly won't but if someone has had experience with this product I would really like to hear their input. I'm thinking I just rebuild the motor when the time and funds become avalible. I just thought I'd ask anyway.
    Feb 2003
    Lake County, Florida
    2,742
    Personally I would just buy a couple of quarts of detergent and add it to the old oil drain some if need be.. . it would do all the cleaning you would need. Run it for a while (15 mins or so) then change your oil.mIt's cheap and it wont hurt your engine..My .02
    Aug 2002
    nw fl
    296
    One of the cons is that it could - emphasize could - break loose a big enough chunk that if it gets stuck to the oil pickup screen would limit oil flow (volume). This isn't a very likely thing since they recommend leaving it in only a short time but it is a possible, especially if you don't drop the pan. Using Rislone, Marvel Mystery oil, ATF or other high detergent oils is basically doing the same thing only with a "milder" cleaner.
    If you're really worried about sludge buildup and are up to spending a few $$$ (~50) you may want to try AutoRx. There are many who swear by it at bobistheoilguy.com but I haven't tried it yet. It's supposed to clean the sludge more gradually and avoid the floating chunks problem.
    Apr 2004
    Boynton Bch,Hurricane Capital of S.Florida
    151
    I had an old school mech tell me to use a qt. of
    tranny fluid with the regular motor oil.
    I haven't tried this because it didn't sound
    like a good idea.But does sound reasonable.
    Feb 2003
    2,742
    Yea...I mean putting brake fluid in the oil of some cars will stop them from smoking..But i wouldn't reccomend doing it on your SC..
    Jul 2003
    South Central Los Angeles
    3,538
    you know what i do, every 3 oil changes, i drain the oil, drain the filter, screw the filter back in, then i pour 1 gallon or more of diesel in,cant remember how much to pour in, run the car for like 5 minutes, and drain it back out, u know how much crap comes out. I was like wow, thats alot of crap, ive never had any problems with this. Never had problems with the oil pick up screen either or oil pressure after that. In fact my oil pressure went up. Not saying you should try it, but at your own risk, take it into consideration
    Allentown, PA
    733
    I used to use that stuff before every oil change back when then car had only 29,000 miles on it. I stopped doing it at around 230,000 miles because I didn't feel like doing it anymore. Well at around 240,000 miles my oil pressure started to fall. So I flushed it with some more of that stuff and the pressure came back. I wouldn't do it on a high mileage car because of the "big chunk " theory, but I had used it from day one and never had a problem.
    Albany, NY, USA
    999
    Gunk oil flush...
    Many of those 5 minute oil flushes are simply higher petrolium distillates. Specifically: Kerosene.
    Or as Darkstar mentioned: Diesel fuel, which is the cousin of Kerosene.
    At the current gas prices, you could probably just use the Diesel fuel.
    I like Darkstar's idea, but I've never put it to practice... Do you really run the engine with a crankcase full of Diesel fuel?
    The risks to the engine I think would be a period of reduced lubrication since the engine flush is actually "washing" the cylinder walls down. It specifically recommends not to drive the car with the stuff in the crankcase, so I would think that it isn't intended to actually lubricate...
    I know people who have seized engines, and have drained the oil, and filled the engine up with Deisel fuel right up to the valve cover and let it sit overnight. The next day they drained the diesel fuel and filled up with fresh oil and oil filter and the engine would turn over!!!! Doesn't always work, but worth a try.
    Imperial, MO (near St. Louis)
    4,343
    Quote Originally Posted by doodaa
    That's exactly what recently happened to a friend of mine. He did an engine flush on his Dakota, then had to bring it to my house to figure out why it had no oil pressure. After pulling the oil pan, my assumption was correct, the oil pickup screen was clogged up with sludge.
    Quote Originally Posted by OneBad89SC
    A few of my friends do this every other oil change or so on their small block chevy's. It seems to work well for them. Transmission fluid works as a detergent to clean out the crankcase.
    -Rod
    Oct 2003
    southern California
    122
    Opinions of Autozone upper cntrl. arms needed!
    Autozone carries all there front end stuff under lifetime warranty. I drive my SC hard, and want to go with higher quality front end parts like Mogg. Being i plan to keep my SC and knowing ill probably need to replace the Upper cntrl. arms/ball joints again, i wanted peoples opinions who have used the Autozone brand "Perfect Circle" for the quality on these. I dont mind to much if they wear out a little faster as long as their sturdy like a higher quality brand for a while atleast. Let me know guys. Thanks
    Aug 2003
    hampton,va
    285
    i have 185,000 on my 91 sc.i had to remove the intake manifold due to gasket leak.and to my shock it was nice and clean in there.but i've always changed the oil every 2500 - 3000 miles and only mobile 1.i bought the car like 2 1/2 years ago from a lady.and she did the same and she only use mobile 1.i'm not much of a fan of that motor flush crap i've heard too many horror stories.i do think my lower half bearings are pretty wore cuz my oil pressure bounces between the n and o on the gauge sometimes it might touch the r.but i imagine if i dropped the pan and just put some bearings in it it would still be around for awhile.really debating on doing this.what do you guys think?or just say screw it and rebuild?i have a spare sc engine (135,000) i could start rebuilding on side(nothing wrong with that engine neither)
    Lakeville, MN
    13,517
    Marvel Mystery Oil!!!
    O.k, now that we have enough different products to try, everyone who said petroleum distilates / kerosene is right!
    Just an agressive light weight oil to help clean things out. Marvel Mystery Oil has been used for doing such things for ages. The other stuff in the can is likely similar.
    The down sides are that a passage-way gets plugged and you loose pressure to a bearing. But I'm not sure how likely that is. If you have a good filter it should be o.k.
    If you've never done it before I'd recommend doing it 50 miles before an oil change. Then change the oil with cheap dino oil, a new good filter, and add another can of the engine cleaner. Drive for 100 miles or so and change the oil again with the good stuff.
    That should clean out most of the stuff pretty good. Then at the next oil change throw a can in about 100 miles before your oil change again. Keep that for the life of the vehicle and it'll keep the inside of the engine pretty clean.
    (personally I'd go with the Marvel Mystery oil.)
    Put NO faith in that gauge. Its more of you have some or you have none gauge. If its fluctuating, its because the sensor is going bad or you have a bad ground.
    Chris
    Sep 2002
    Ensenada B.C. Mexico
    1,223
    dont we have like to get the engine out to remove the oil pan? it looks very very near to the subframe.
    4,343
    Quote Originally Posted by turbospeed
    Either that or drop the K-member.
    -Rod
  1. Looking for proper way to do KOER test
    Last Post: 04-22-2005, 11:58 PM
  2. Anyone Use GUNK Engine De-greaser??
    By ZeeK in forum Technical Forum
    Last Post: 03-28-2004, 05:59 PM
  3. Maintenance Schedule?
    By Flip in forum New SC Owner Forum
    Last Post: 08-31-2003, 07:36 PM
