E
EdmontonSuperCoupe
Guest
Need help ASAP...... Problem with starter......
Now the other day i went to start my car and its doing something really f**ked up..... When i start it the starter keeps on going..... If i turn off the car, no matter where i turn the key the starter keeps on cranking the engine. The only way i can stop the starter from cranking is to dissconnect and then reconnect the battery.. Now i tried changing the starter relay under the hood and it didn't work.... Now the next option is to change the starter but is there something else that it can be that i can check, cuz i really don't want to spend $200 on a new starter and find out that it wasn't the problem
