Rich Thomson
Maybe another FAQ?
8.8 Differential Rebuild Kits:
Master 8.8 differential kit Part RA311 (parts below included in kit)
Axle differential bearing (2 needed) part number A36
Front differential pinion bearing cone part number M802048
Front differential pinion bearing cup part number M802011
Rear differential pinion bearing cone part number M88048
Rear differential pinion bearing cup part number M88010
Differential pinion seal part number 3604
Pinion nut
Crush sleeve
IRS Axle shaft oil seal (2 needed) part number 714569 (Part not included in kit but needed for IRS 8.8 rebuild ) Try www.rockauto.com for BCA parts.
8.8" RING & PINION INSTALLATION KIT M-4210-A (Ford Racing)
Kit includes; pinion & carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts and cover gasket (Use for changing ring and pinion gear or differential)
Pinion & carrier shims, ring gear bolts, gasket, crush sleeve, pinion nut, pinion seal
8.8" RING & PINION INSTALLATION KIT M-4210-B (Ford Racing)
Kit includes everything that M-4210-A has and pinion gear and carrier bearings (Use for changing ring and pinion gear or differential)
Pinion & carrier shims, ring gear bolts, gasket, crush sleeve, pinion nut, pinion seal PLUS carrier bearings & pinion gear
8.8" RING & PINION INSTALLATION KIT M-4210-C (Ford Racing)
Kit includes everything that M-4210-B has and axle shaft bearings and axle shaft seals (Use for changing ring and pinion gear or differential)
Pinion & carrier shims, ring gear bolts, gasket, crush sleeve, pinion nut, pinion seal PLUS carrier bearings & pinion gear PLUS axle shaft seals and axle shaft bearings
8.8" HEAVY DUTY PINION SHIM KIT M-4663-A (Ford Racing)
Relocates pinion shim from between the pinion gear head and the bearing to between the bearing race and the housing
8.8 Traction Lock rebuild kit M-4700-B (Ford Racing)
Kit includes: Clutch Pack, Shims, Friction modifier and instruction kit. Fits all 8.8 T-lock Differentials
Pinion nut
Crush sleeve
