fastsc92
Alright guys, i finally got my air/fuel squared away except my tip-in. It seems to spike slightly to around 16.5-17:1. This only last under 2 tenths of a second however. I trying playing around with my accel vs tps table, and had no luck there. I changed the accel table to these values as well:
ACCEL_ENRICHMENT_VS_TPS # Accelerator Enrichment Multiplier vs TP voltage
( 4.98047, 0.5 ) ( 4.0001, 0.5 ) ( 3.8, 0.5 )
( 3.25, 0.5 ) ( 2.44141, 0.75 )
ACCEL_ENRICHMENT_FUEL_TABLE # Accelerator Enrichment Fuel Table(lb/min)
15 20 20 30 40 60 8 7
12 15 20 30 40 60 6 6
10 12 15 20 40 50 5 5
8 10 9 10 15 30 4 4
7 7 5 7 10 20 2 2
4 4 4 4 7 10 1 1
0 0 0 0 0 5 0 0
Here is a screen shot of a 3rd gear pass at WOT. As you can see it is exactly what i commanded ( 12.1:1), but the tip-in is off. (A/F top row, bottom row TPS) Can you guys help me figure out what to change. I dont really understand the throttle rate, and how to know which number to change in the accel table. Besides that i think i'm getting the hang of it.
On a lighter note i changed my fuel tables to command 11.5 :1 and it does exactly what i comand. So i know my MAF fuctions is dead on. When i command 11.5, it does. I pulled the octane plug to make a nitrous run (65hp). With the plug pulled (retard 4 deg) and a commanded ratio of 11:0, the car dials in at 10:1. With the ignition not retarded, it dials in at 12:1. So i'm thinking with 2 deg retard ( like the manual says for a 65 shot) then i should hit 11:1 like i command.
These are just a few questions in my head, but my major concern is my tip-in. Any help would be great guys.
8 10 9 10 15 30 4 4
7 7 5 7 10 20 2 2
4 4 4 4 7 10 1 1
0 0 0 0 0 5 0 0
