Results 1 to 5 of 5
Thread: Non-functional power seat motor...how to remove seat?
    SCCoA Member#1257
    3,302
    Any recomendations? The worst thing is that the seat is positioned right above the two rear bolts so i cant get anything to fit under there to get them removed. I hope some of you can get me some tips.
    Lakeville, MN
    13,517
    There are four nuts that hold it down. One on each corner. Pull the plastic covers off the bolts and wrench them off. The rear ones can be hard to get at without moving the seat forward and I'm not sure how to move it forward without assist. This because they are on the inner side of the rails. A box end wrench should be able to get it done.
    The fronts are easier as they are at the tip of the rails.
    SCCoA Member#1257
    3,302
    I got the two front bolts out, but the problem lies in the rear ones. The seat is over those so i cant even see how to get to the rear two.
    Aug 2002
    nw fl
    296
    You may be able to get at them from about a 45 degree angle with a long extension and a u-joint on the socket.... That's how I got the fronts with the seat all the way forward.
    Aug 2002
    LONDON ONT. KANaDa
    891
    power
    my computer chair is SC seat hooked to a battery charger ....under seat find power plug [grey] 2 prong with a black wire[-] and a black with white stripe [+] find some screws ...2 of them ...screw them in between the prongs and the plastic case and hook up battery charger ...and see if you have power and a good ground ...first ...maybe no need to remove seat ...there is also another connector under the seat that may of been pulled apart ...while the seat was moving ..they are reachable with the seat still in the car ....dave
  1. My head gasket how-to
    Last Post: 05-15-2009, 01:18 AM
  2. Power driver's seat
    By rock5 in forum Non Technical Forum
    Last Post: 12-21-2003, 02:47 PM
  3. Trade power for manual passenger seat in 95
    By Peterdroy66 in forum Super Coupe Club of Ontario
    Last Post: 08-01-2003, 05:18 PM
  4. Power seat track swap??
    By MTTod in forum Technical Forum
    Last Post: 04-19-2003, 12:48 PM
