Results 1 to 7 of 7
Thread: amp wiring
    Jul 2004
    Cedar Falls, Ia
    56
    amp wiring
    Im having problems running my RCA and remote wires from my cd player to the trunk for my amp. The rear seats dont fold down. Should/could i remove the whole seat, run the wires back to the trunk and then replace the seat?
    Feb 2003
    Wichita, KS
    1,653
    re
    The bottom of the seat comes off very easily, so remove that and then you can fish the wires through.
    Push down on the seat with your knee and push it back towards the trunk with your hand at the same time to remove it. There are 2 spots it is connected at.
    Jul 2004
    Cedar Falls, Ia
    56
    rear seat
    youre talking about just the bottom seat part just comming out, not the back of the seat too?
    Feb 2003
    Wichita, KS
    1,653
    Just the bottom, it is very easy to do espicially after you do it once. Give me a call if you can't get it, but I will be going to bed shortly after 8.
    Julian - 515-290-2296
    Jul 2004
    Cedar Falls, Ia
    56
    rear seat out
    K i got the seat out, but im not finding a way to get the wires to the trunk.
    Feb 2003
    Wichita, KS
    1,653
    Just fish them under the remaining seat. You may need to cut a metal coat hanger and use it to fish the wires through.
    You should be able to kind of reach you hand/fingers under the bottom of the remaining seat and get them into the trunk.
    Blair, Nebr
    3,292
    When I ran my wires, I fished them underneath the backseat like Julian is describing.. After the seat bottom is up, look near the seat belt buckes. There was a small opening that was still large enough for me to get all the wires through.
    -Andy "Melon"
  1. Amp wiring
    By steveo86 in forum Technical Forum
    Last Post: 04-02-2004, 04:56 PM
  2. JBL Subwoofer AMP to Spkr in enclosure wiring
    By Peterdroy66 in forum Technical Forum
    Last Post: 08-17-2003, 06:36 PM
  3. placing new amp in place of stock amp?
    By LikeNew92 in forum Technical Forum
    Last Post: 11-02-2002, 07:42 AM
  4. 2nd amp wiring question
    Last Post: 10-21-2002, 02:54 AM
