Results 1 to 5 of 5
Thread: Please Help To Identify The Crank Sensor
    Jul 2003
    Puerto Rico
    73
    Could someone tell me what of the following parts is the crank sensor, my problem is car crank but not start, the upshift light goes on every time i crank.
    Thanks!
    21,151
    No that's the camshaft sensor. The crankshaft sensor is where the arrow on the diagram is pointing. It's mounted behind the dampener/balancer but can be changed without removing the balancer. Before changing, check to make sure your belt didn't rub thru the wires that go down to it.
    Jul 2003
    Puerto Rico
    73
    Where i can find info to know the steps and tips to change.
    PS - Thanks!
    Oct 2003
    Albuquerque, NM
    1,609
    That's the cam sensor you are pointing at. There's a disscussion about this a couple of threads down from yours. Here is the link:
    LINK
    Jul 2003
    Puerto Rico
    73
    Thanks guys! i going to check all post to see if i can change the sensor without removing the balancer.
  2. Wide band O2 w/ digital display in car
    By kuhnga in forum Technical Forum
    Last Post: 12-04-2004, 11:55 AM
  3. Crank Sensor Help!!!! How Hard Is To Change?
    By wingrg in forum Technical Forum
    Last Post: 07-19-2004, 10:28 AM
  4. Car only runs with diag scanner on...PLEASE HELP!!!
    By Mike Manzo in forum Technical Forum
    Last Post: 11-17-2002, 05:42 PM
